[Qgis-user] Re: No projection systems available on 0.11 (ubuntu)
Maciej Sieczka
tutey at o2.pl
Wed Jul 23 08:58:51 PDT 2008
Craig Leat pisze:
> Hi
> I have just built qgis trunk (revision 8821) on ubuntu 7.10 and I am
> seeing the same lack of srs info. In my case I have 0.10 installed
> from the ubuntu repository on launchpad and this version loads the
> srs data just fine. The trunk version however, only loads my custom
> projections from /home/craig/.qgis/qgis.db the standard geographic
> and projected systems are unavailable.
> Following Albin's experience described earlier it appears that I need
> to clean up the 0.10 install. Can this be done without destroying
> it?
What do you mean by "destroying it"? Just remove+purge in Synaptic all
QGIS components, remove leftovers from the filesystem if you have any
(you *don't* need to erase any QGIS-related files under your home dir),
install 0.11 and tell us how it went :).
Maciek
Maciej Sieczka
www.sieczka.org
