[Qgis-user] Grass plugin not appearing in plugin manager
asroberts
asroberts at yahoo.com
Wed Jul 23 16:44:23 PDT 2008
Hi all,
I am just starting to work with QGIS 0.11.0 under Kubuntu Gutsy. I have not been able to find or install the GRASS GIS plugin in the plugin manager.
When I start QGIS from the terminal, I get the following error message:
ERROR 1: libgrass_I.so: cannot open shared object file: No such file or directory
I have both GRASS 6.2.3 and qgis-plugin-grass 0.11.0-2 (along with its libraries) installed.
I have confirmed that libgrass_I.so does exist in /usr/lib/grass/lib. So I tried copying it to /usr/lib/qgis. This had no effect.
Following a suggestion from one of the emails in this list's archive, I also tried to edit my /etc/ld.so.conf file by adding a line with, "/usr/lib/grass" but this did not seem to help either. Though I have never edited the ld.so.conf file before, so I may have not used the correct syntax.
Does any one have any ideas where my problem might be?
Thank you!
-Andy.
Send instant messages to your online friends http://uk.messenger.yahoo.com
