[Qgis-user] printing with metis?
Michael Neubauer
Neubauer-Michael at gmx.net
Mon Jul 28 21:53:36 PDT 2008
Hi Tara,
in the print-composer you have to press "add a new map", then draw a square
with your mouse on the canvas in the size you want to have the active view in
the map-composer displayed and then press the button "add a new map" again.
I think I remember, that in older versions you did not have to press "add a
new map" a second time. That might have lead to some confusion...
Hope my answer helps you and is still in time.
Good trip with the map... ;-)
Micha
Am Dienstag 29 Juli 2008 07:49:59 schrieb Tara Athan:
> I am having trouble printing from v 0.11
> (Platform- WinXP)
> I tried Quickprint, but the labels came out HUGE. I tried changing label
> size to map units instead of points, but had same problem.
> I then tried the Print Composer - I was not able to add the map layer to
> the canvas. I clicked on the add map tool, but it just flashed and
> nothing happened. I tried clicking on the canvas at that point, and
> clicking and dragging, but no result.
> I had to get a printout because I am going out in the field tomorrow, so
> I took a screen capture, shoved it into GIMP, saved as jpg and printed
> that. That worked, so I know I'm not bonkers and have a working printer
> connection.
> Any suggestions?
> Thanks, Tara
> Qgis-user mailing list
