[Qgis-user] v0.9.2 Add Delimited Text Layer
David Fawcett david.fawcett at gmail.com
Fri Jun 6 11:37:22 PDT 2008
I had a similar problem with a comma-delimited text file using 0.10.
I am guessing the problem was related to the fact that some of the
values in the file have commas in them.  The values are quoted, but I
would bet that they are what is causing the issue.
On Fri, Jun 6, 2008 at 11:28 AM, Goyo <goyodiaz at gmail.com> wrote:
> I don't have this problem since I updated to 0.10. Using Ubuntu Hardy
> Heron and package 0.10.0-6 from http://ppa.launchpad.net/qgis/ubuntu.
> El mar, 27-05-2008 a las 19:50 -0700, Ceolin escribió:
>> Same distro, same problem!
>> flohCardiff wrote:
>> > Hi everybody,
>> > Any solution to the problem? I am using Ubuntu Hardy Heron, with Quantum
>> > GIS 0.10 and end up in "The layer is not a valid layer and can not be
>> > added to the map" when I try to load my ascii point files. Parsing seems
>> > to work, I can set the headers and the file appears in the preview.
>> > Any pointers to solve the problem appreciated.
>> > Florian
> Qgis-user mailing list
