[Qgis-user] morphing two polygons
cfarmer cfarmer at uvic.ca
Tue Jun 10 22:47:08 PDT 2008
Ken,
I have been thinking about a similar problem myself in terms of spread.
This ends up being pretty much the opposite to your problem I guess...
What is is that you would like to do with the intermediate polygons? Is it
just for visualization, or would you need actual polygon files to work
with?
I would be interested to hear more about what you are doing: feel free to
email me directly about this... I may have a solution in the works for you
Carson
> Hi all,
> I have been mucking around with some thoughts on how I might morph from
> an original polygon to a larger polygon, showing the intermediate steps
> in between and thought I would see if anyone has done this in QGIS or
> had any suggestions.
> So I have polygon A that shows a large blob, polygon B that shows that
> same blob much reduced in size. Assuming an even reduction in size, I
> want to create a polygon of that lake at different intervals of change
> between A and B. Hope that makes sense.
> My original thinking was to pretend the two polygons are contour lines
> and interpolate between them, then convert the interpolated countours to
> their own polygons. Any other thoughts on this?
> Thanks,
> Ken
> This message has been scanned for viruses and
> dangerous content by MailScanner, and is
> believed to be clean.
> Qgis-user mailing list
Carson Farmer
Spatial Pattern Analysis & Research Lab (SPAR)
Department of Geography, University of Victoria
PO Box 3050 STN CSC
Victoria, BC, V8W 3P5,Canada
www.geog.uvic.ca/spar
cfarmer at uvic.ca
