[Qgis-user] How to project data?
cfarmer
cfarmer at uvic.ca
Mon Jun 16 09:12:13 PDT 2008
John,
Rasters cannot be projected in QGIS as of yet, however, you can use the
georeferencing plugin to georeference them. As for vector layers, you can
project them on the fly by assigning their projection using the projection
dialog, or you can hard project them using my srsmanagement plugin. This
plugin also allows you to define the projection.
It is available here:
http://www.geog.uvic.ca/spar/carson/
or if you have QGIS > 0.9.2 you can add:
http://www.geog.uvic.ca/spar/carson/cfarmerQgisRepo.xml
to your python plugins repository in your plugin installer and install it
directly from there.
There are instruction at the address above as well...
Cheers,
Carson
> I apologize for asking a question that seems so trivial but I am having
> a hard time understanding how QGIS manages coordinate systems. How do I
> project a vector or raster dataset? Just as important, how do I define
> a projection/coordinate system? Is this done through the QGIS
> interface or do I accomplish this outside QGIS using command line
> GDAL/OGC utilities? Thanks for your help.
> - John
> John Callahan
> Geospatial Application Developer
> Delaware Geological Survey
> University of Delaware
> 227 Academy St, Newark DE 19716-7501
> Tel: (302) 831-3584
> Email: john.callahan at udel.edu
> http://www.dgs.udel.edu
> Qgis-user mailing list
Carson Farmer
Spatial Pattern Analysis & Research Lab (SPAR)
Department of Geography, University of Victoria
cfarmer at uvic.ca
