[Qgis-user] Re: add a gml layer
Borys Jurgiel borys at wolf.most.org.pl
Fri Jun 20 15:43:52 PDT 2008
I think it's related to the GDAL built in the 0.10 version for Windows. I've
just noticed the same problem with this version, whereas the linux versions
(both 0.10 and 0.11) open the file (created by ogr2ogr, not every GML of
course) with no problem. I have no possibility to test it in the 0.11 for
Win.
Friday 20 of June 2008 23:16:00 Tara Athan napisał(a):
> I was able to get a lakes.gml file using the procedure Jürgen suggested,
> using FW Tools.
> It still does not load into QGIS v.10 (Windows XP) however.  The error
> is the same as before-
> ...\lakes.gml is not a valid or recognized data source
> However I checked with a Windows build of QGIS v.11 that I received on
> 6/6/08, and the layer DOES load!
> I am guessing it is a re-emergence of closed Ticket #751 in the Io
> Windows build.
