[Qgis-user] Re: add a gml layer
Otto Dassau
otto.dassau at gmx.de
Sat Jun 21 00:06:48 PDT 2008
On Fri, 20 Jun 2008 23:39:24 -0700
Tara Athan <tara_athan at alt2is.com> wrote:
> Otto Dassau wrote:
> > Hi Tara,
> > maybe we should find out, if the windows QGIS version you use includes a
> > GDAL
> > with GML support. What version do you use?
> The version that has problems with the GML import is QGIS v.10.0,
> Windows package. The last-modified date on my copy of the installer is
> May 11, if that makes any difference.
> I don't know how to find out details of the GDAL that is included with
> this build.
I don't know :-). Usually the person who build that package can say more and i
guess it would be helpful put a list of supported formats somewhere (if it
doesn't already exist).
I downloaded the 0.10.0 windows exe from http://download.qgis.org/ and I don't
have GML support either, so I guess it is not a bug but a missing GML support in
GDAL.
regards,
Otto
> > I remember GML was not always
> > included as a supported format in former QGIS Windows versions.
> > regards,
> > Otto
> > On Fri, 20 Jun 2008 14:16:00 -0700
> >> I was able to get a lakes.gml file using the procedure Jürgen suggested,
> >> using FW Tools.
> >> It still does not load into QGIS v.10 (Windows XP) however. The error
> >> is the same as before-
> >> ...\lakes.gml is not a valid or recognized data source
> >> However I checked with a Windows build of QGIS v.11 that I received on
> >> 6/6/08, and the layer DOES load!
> >> I am guessing it is a re-emergence of closed Ticket #751 in the Io
> >> Windows build.
> >> Can anyone verify this?
> >> Tara
