R: R: [Qgis-user] Postgis SSL connection
marco.pasetti at alice.it
Wed May 7 01:55:05 PDT 2008
Hi Andreas,
>Why? Does the Windows QGIS version support SSL?
Sorry but not!
It's an item in my ToDo List. I must compile OpenSSL, PostgreSQL with OpenSSL support, and then GDAL, GRASS (both with PostgreSQL and SQLite support) and, finally, QGIS.
Since it's a long work, I put this ToDo item along with others environment update items, to be done for the next releases of both GRASS and QGIS.
This said, if you need that support on Linux, you must perform the above build sequence: SSL->PostgreSQL (8.2.* suggested, because of building issues of QGIS with 8.3.*)->GDAL (with PostgreSQL and SQLite support)->GRASS (with PostgreSQL and SQLite support)->QGIS.
Marco
Da: qgis-user-bounces at lists.osgeo.org per conto di Andreas Neumann
Inviato: mer 07/05/2008 10.29
A: qgis-user at lists.osgeo.org
Oggetto: Re: R: [Qgis-user] Postgis SSL connection
Hi Marco,
Sometimes I am a Windows user (if I have to). But some of the other users
using the same server are also Windows users. I mainly use Linux at work
and MacOSX on my private notebook.
Thanks,
Andreas
> Hi Andreas,
> are you a Windows user?
> Marco
> Inviato: mer 07/05/2008 9.05
> Oggetto: [Qgis-user] Postgis SSL connection
> Hi all,
> I have a Postgis server that only allows SSL connections (also on port
> 5432). While I can easily connect to it using psql or pgadmin3, it seems
> like QGIS can't connect using SSL. Is there a compile option to add SSL
> support to the Postgis driver?
> If this functionality is still missing, how much effort would it be to add
> such an option to QGIS? I guess one would have to use the OpenSSL
> libraries for that purpose.
> Thank you for any hints/information.
> Andreas
> Andreas Neumann
> Böschacherstrasse 6
> CH-8624 Grüt (Gossau ZH)
> Switzerland
> Phone: ++41-44-2736668
> Email: a.neumann at carto.net
> Web: http://www.carto.net/neumann/
> SVG Examples: http://www.carto.net/papers/svg/samples/
> SVG.Open: http://www.svgopen.org/
> Qgis-user mailing list
Andreas Neumann
Böschacherstrasse 6, CH-8624 Grüt/Gossau, Switzerland
Email: a.neumann at carto.net, Web:
* http://www.carto.net/ (Carto and SVG resources)
* http://www.carto.net/neumann/ (personal page)
* http://www.svgopen.org/ (SVG Open Conference)
* http://www.geofoto.ch/ (Georeferenced Photos of Switzerland)
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20080507/70021994/attachment.html>
