[Qgis-user] symbol lookup error on kubuntu 8.04
Tim Sutton
tim at linfiniti.com
Wed May 7 08:46:19 PDT 2008
Hi (please reply on-list so others may learn from solutions found if
they encounter similar problems)
2008/5/7 andrea pacifici <pacifici at gmail.com>:
> ok, thanks
> I need /media/data_2/isis3/isis/3rdParty/lib.
> How can I adjusts ldconfigs to ensure the libraries in /usr/lib get priority
It depends on how your system is configured really, and how the isis
app you have installed itself. Firstly check your ~./bashrc to check
if anything is setting LD_LIBRARY_PATH variable. Secondly if you have
root access to your machine you can inspect and adjust
/etc/ld.so.conf. You might also want to check if anything got changed
in /etc/bash_profile etc. You should probably take this up with
developers of the ISIS app that you are using since it seems in
setting it up the process has broken your lib search order.
Regards
Tim
> Thanks
> Andrea
> 2008/5/7 Tim Sutton <tim at linfiniti.com>:
> > Hi
> > > Yes, thanks. It is quite long
> > No problem.
> > > andrea at solaria:~$ ldd /usr/lib/libqgis_gui.so.0.10
> > > linux-gate.so.1 => (0xb7fa1000)
> > > libQtGui.so.4 =>
> /media/data_2/isis3/isis/3rdParty/lib/libQtGui.so.4
> > > (0xb7a38000)
> > Ok that looks like the cause of your problem - it looks like you have
> > some other copy of qt4 on your system that has priority in the library
> > load sequence. Either remove the libs in
> > /media/data_2/isis3/isis/3rdParty/lib (if not needed) or adjust your
> > ldconfigs to ensure the libraries in /usr/lib get priority.
> > 8<----------snip------------
> > Regards
> > Tim Sutton
> > QGIS Project Steering Committee Member - Release Manager
> > Visit http://qgis.org for a great open source GIS
> > openModeller Desktop Developer
> > Visit http://openModeller.sf.net for a great open source ecological
> > niche modelling tool
> > Home Page: http://tim.linfiniti.com
> > Skype: timlinux
> > Irc: timlinux on #qgis at freenode.net
> _____________________________
> Dott. Geol. Andrea Pacifici, Ph.D.
> Via della Billona n°1093,
> 55100 Lucca (Lu)
> Cell. 328-0991808
> E-Mail pacifici at gmail.com
Tim Sutton
Skype: timlinux
