[Qgis-user] Qgis "segmentation fault" in Fedora 9
Jan Valenta
valenta at irsm.cas.cz
Fri May 16 02:05:11 PDT 2008
I have the same problem in Fedora 9. It is the same with the 0.9.1
version from the fedora repository as well with the 0.10.0 version
compiled by myself.
>From the gdb:
(no debugging symbols found)
Warning: No valid projection. Unable to set map units.
Program received signal SIGSEGV, Segmentation fault.
0x02ed18e6 in sincos () from /usr/lib/libgdal.so.1
(gdb)
Any ideas what went wrong?
Jan.
> Hi,
> I recently switched from Ubuntu Hardy H. to Fedora 9 (gnome). Of course
> I wanted to install Qgis as my first app. But after installing
> "qgis-0.9.1-5.fc9(i368)" via PackageKit and running it, I only see the
> splash screen for 1 second and then qgis closes with "Segmentation
> fault" (when started on the command line)". What can I do?
> Thanks for helping out. Carlo
