[Qgis-user] Change Projection in Projection Properties from a Python PlugIn
bjsvwpfe Michael.Pfeiffer at bd.so.ch
Wed May 28 08:36:50 PDT 2008
Hi everybody,
is it possible to change the projection which is set in the Projection
Properties from a Python-PlugIn.
Within the PlugIn I want to load some layers into QGIS.
To save the plugin users of changing projection properties I want to set the
properties in the plugin.
Maybe its possible with qgsProjectProperties? I didn't find a solution so
far. To change the mapUnits in the plugin is possible with setUnits in the
mapCanvas. But what about the projection?
So any hint would be appreciated
Thanks
Greetings
Michael
View this message in context: http://www.nabble.com/Change-Projection-in-Projection-Properties-from-a-Python-PlugIn-tp17515568p17515568.html
Sent from the qgis-user mailing list archive at Nabble.com.
