[Qgis-user] Change Projection in Projection Properties from a Python PlugIn
Carson Farmer
cfarmer at uvic.ca
Wed May 28 16:09:54 PDT 2008
Martin, a quick question regarding this operation:
If I were to setDestinationSrs, and on the fly projection was enabled,
will this change be reflected on screen? I ask because I would like to
be able to dynamically 're project' two vector layers on the fly during
plugin operation, without the user dessesarily 'seeing' that this is
happening, is this possible?
Cheers,
Carson
Martin Dobias wrote:
> On Wed, May 28, 2008 at 5:59 PM, Ziegler Stefan <Stefan.Ziegler at bd.so.ch> wrote:
>> Hi Michael
>> this is what I bookmarked a few days ago (for the same reason):
>> http://doc.qgis.org/classQgsMapRender.html
>> -> setDestinationSrs(...)
> Hi,
> yes, Stafan is right, you can access map canvas by plugin interface,
> access its QgsMapRender instance (by mapRender() function) and change
> the destination SRS with the function mentioned above.
> Good luck
> Martin
> Qgis-user mailing list
