[Qgis-user] Help on creating a view
Francis Dupont
Francis.X.Dupont at USherbrooke.ca
Thu May 29 07:40:22 PDT 2008
Hello!
I have two tables named myPtTable and myPolyTable on a PostGIS/PostgreSQL
8.3 server. I want to join the two table based on a spatial query has
following:
SELECT a.gid, b.gid, a.level, b.name a.the_geom
FROM myPolyTable a, myPtTable b
WHERE st_contains(a.the_geom, b.the_geom)
ORDER BY a.level, a.gid;
The columns a.gid and b.gid are both primary key of type integer. I read on
the forum that the way to join those tables and see them in QGIS (Io 0.10)
is done by using a view. So I've done it but QGIS always give me the same
error that my view need a primary key. The real primary key is the two gid
field because I have a N to N relationship between my two tables. I saw on
the forum that it is a bug in QGIS that will be fixed someday. What's the
solution? To quick test if the view functionnality works in QGIS, I have
create the following query:
SELECT a.gid, a.level, a.the_geom FROM myPolyTable a
But in fact, my view still doesn't work in QGIS and a.gid is a PRIMARY KEY
with UNIQUE VALUE constraint.
I would like help from the community on that problem.
Does the view functionnality work in QGIS? If so, can I have a sample to
try it. To join my two table, how can I create a primary key based on my
two fields in my view?
Thank you,
Francis
View this message in context: http://www.nabble.com/Help-on-creating-a-view-tp17536251p17536251.html
Sent from the qgis-user mailing list archive at Nabble.com.
