[Qgis-user] How do I get manageR under Ubuntu 8.04 - 64 bit working?
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Fri May 30 11:37:33 PDT 2008
I am facing this strange problem:
I could not get manageR loaded. I've installed all possible dependencies
(as far as I could find searching the web) and it worked. After I
install rgdal in R it stoped working!!! What did the installation of
rgdal "hurt"?
Thank you Nikos
P.S. I get following message on qgis start-up:
Couldn't load plugin "manageR" from ['/home/nik/.qgis//python/plugins',
'/usr/share/qgis/python', '/usr/share/qgis/python/plugins',
'/usr/lib/python25.zip', '/usr/lib/python2.5',
'/usr/lib/python2.5/plat-linux2', '/usr/lib/python2.5/lib-tk',
'/usr/lib/python2.5/lib-dynload',
'/usr/local/lib/python2.5/site-packages',
'/usr/lib/python2.5/site-packages',
'/usr/lib/python2.5/site-packages/Numeric',
'/usr/lib/python2.5/site-packages/PIL',
'/usr/lib/python2.5/site-packages/gst-0.10',
'/var/lib/python-support/python2.5',
'/usr/lib/python2.5/site-packages/gtk-2.0',
'/var/lib/python-support/python2.5/gtk-2.0',
'/usr/lib/python2.5/site-packages/wx-2.8-gtk2-unicode',
'~/.qgis/python']
File "", line 2, in
File "/home/nik/.qgis//python/plugins/manageR/__init__.py", line 35,
in
from manageR import manageRPlugin
File "/home/nik/.qgis//python/plugins/manageR/manageR.py", line 40, in
import domanageR
File "/home/nik/.qgis//python/plugins/manageR/domanageR.py", line 39,
in
from rpy import *
File "/usr/lib/python2.5/site-packages/rpy.py", line 134, in
""" % RVERSION)
RuntimeError: /usr/lib/atlas/liblapack.so.3: undefined symbol: ATL_chemv
RPy module can not be imported. Please check if your rpy
installation supports R 2.7.0. If you have multiple R versions
installed, you may need to set RHOME before importing rpy. For
example:
>>> from rpy_options import set_options
>>> set_options(RHOME='c:/progra~1/r/rw2011/')
>>> from rpy import *
