[Qgis-user] New plugins: profiles and table management
Alessandro Sarretta
alessandro.sarretta at inwind.it
Fri May 30 13:29:33 PDT 2008
Hi Borys, and thank you for your plugin for table management, surely it
is a fundamental tool!
I tried to use it inserting, deleting, cloning, renaming a vector
polygon layer in my QGIS 0.10.0 in Windows XP.
When I save it, it starts to work until 20-30 %, but then it stops and
shows me this error message:
>An error has occured while executing Python code:
>Traceback (most recent call last):
> File "C:/Documents and
Settings/Ale/.qgis//python/plugins\tablemanager\doTableManager.py", line
504, in doSaveAs
> print "babajaga"
>IOError: [Errno 9] Bad file descriptor
What could be the cause of this error?
Another little observation is that, when I rename a column, it
transforms all small letters in capital letters.
Alessandro
Borys Jurgiel ha scritto:
> Ladies and Gentlemans,
> Sorry I was so quiet last days, but I was writting a few plugins. A first
> three of them are already usable, so I ask you to testing :) Since my English
> is rather poor, also any language fixes will be priceless...
> Path to the repository:
> http://www.bwj.aster.net.pl/qgis/plugins.xml
> and to the little description:
> I hope you will like they. Also I have two questions:
> 1) "Point profile - The tool for collecting polygon attributes from multiple
> layers at specified sampling points". I'm not sure if is this name and
> description obvious? Mabye there is better word for describe this function
> already?
> 2) License problem. I used a few icons from QGIS main interface and two ones
> from a KDE theme, published under LGPL license. Do I have to mention about
> their origin? And can I use LGPL-licensed icons in the GPL-licensed program?
> Maybe the easiest way is to paint similar ones myself?
> Now I'm getting down to the Plugin Installer/updater. Sorry I didn't answer
> yet!
