[Qgis-user] QgsGeometry - how to detect nr of rings and vertices
Carson Farmer
carson.farmer at gmail.com
Tue Nov 11 02:47:29 PST 2008
Hi Andreas,
> I am using QgsGeometry from python. I would like to find out the nr of
> rings and vertices per ring but could not find a function for this purpose
> in http://doc.qgis.org/classQgsGeometry.html
I don't think there is one...
> Is there something hidden/undocumented to find out this information?
> The idea is to step through all rings and vertices of a QgsGeometry object
> and process the coordinates.
The fTools function extract nodes does something like this (only it's
not especially efficient...)
What about something like:
ring_count = 0
vertices_count = 0
geom = QgsGeometry() # doesn't matter how you get this ;-)
# figure out the geometry type() here
if geom.type() == QGis.Polygon:
if geom.isMultipart():
polygons = geom.fromMultiPolygon()
else:
polygons = [ geom.fromPolygon() ]
for polygon in polygons:
for line in polygon: # these are your rings
print ring_count
for vertices in line: # these are your vertices
print vertices_count
Obviously you wouldn't really loop through all of the vertices and rings
this way, but you can use this concept to figure out how many of each
there are:
num_rings = len( polygon )
num_vetices = len( line )
I don't know if this is what you were looking for, but hopefully it helps,
Carson
Carson J. Q. Farmer
ISSP Doctoral Fellow
National Centre for Geocomputation (NCG),
John Hume Building,
National University of Ireland, Maynooth,
Co. Kildare,
Ireland.
Phone: +353 (0) 1 708 6726
Fax: +353 (0) 1 708 6456
Email: Carson.Farmer at gmail.com
Web: http://www.carsonfarmer.com/
http://www.ftools.ca/
