[Qgis-user] Ftools Join attributes
Tim Sutton
tim at linfiniti.com
Wed Nov 12 23:07:41 PST 2008
Hi Dane
That looks like it is using API changes present in QGIS 1.0 preview 2
only. William has just updated his packages to include a Mac build of
QGIS 1.0 preview 2 now:
http://www.kyngchaos.com/wiki/software:qgis
Note that the ftools_preview1 and fTools_preview2 refer to which QGIS
1.0 preview build they are compatible with.
Hope that helps!
Regards
Tim
On Wed, 2008-11-12 at 19:43 -0800, Dane Springmeyer wrote:
> Hey Carson,
> Just tried loading up both your ftools_preview1 in and fTools_preview2
> to test out the Join Attributes feature using Williams 1.0.0preview1
> build for Mac OS 10.5.
> I get this error below that I thought you might like to see.
> Cheers,
> Dane
> An error has occured while executing Python code:
> Traceback (most recent call last):
> File
> "/Users/spring/.qgis//python/plugins/fTools_preview2/fTools_preview2.py", line 318, in dojoinAttr
> d = doJoinAttributes.Dialog( self.iface )
> File
> "/Users/spring/.qgis/python/plugins/fTools_preview2/tools/doJoinAttributes.py", line 59, in __init__
> layer = mapCanvas.layer(i)
> AttributeError: layer
> Python version:
> 2.5.1 (r251:54863, Jan 17 2008, 19:35:17)
> [GCC 4.0.1 (Apple Inc. build 5465)]
> Python
> path:['/Applications/qgis1.0.0.app/Contents/MacOS/share/qgis/python',
> '/Users/spring/.qgis//python/plugins',
> '/Applications/qgis1.0.0.app/Contents/MacOS/share/qgis/python/plugins', '/Library/Python/2.5/site-packages/GDAL-1.5.2-py2.5-macosx-10.5-i386.egg', '/Library/Python/2.5/site-packages/python_openid-2.2.1-py2.5.egg', '/Library/Python/2.5/site-packages/python_yadis-1.1.0-py2.5.egg', '/Library/Python/2.5/site-packages/nik2img-0.2.1SVN-py2.5.egg', '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python25.zip', '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5', '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/plat-darwin', '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/plat-mac', '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/plat-mac/lib-scriptpackages', '/System/Library/Frameworks/Python.framework/Versions/2.5/Extras/lib/python', '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/lib-tk', '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/lib-dynload', '/Library/Python/2.5/site-packages', '/Library/Python/2.5/site-packages/PIL', '/Library/Python/2.5/site-packages/setuptools-0.6c8-py2.5.egg', '/usr/local/lib', '/System/Library/Frameworks/Python.framework/Versions/2.5/Extras/lib/python/PyObjC', '/Users/spring/.qgis/python/plugins/fTools_preview2/tools']
> Qgis-user mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Visit http://linfiniti.com to find out about:
* QGIS programming services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting & Support Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20081113/b8ea766f/attachment.sig>
