[Qgis-user] Mac OS X: QGIS 1.0 Preview 2 Crashes
Dan Dittmann qgis at dandittmann.org
Thu Nov 13 17:55:09 PST 2008
I am unable to run QGIS 1.0 Preview 2 because the application quits
out before completely launching.
Numerous messages are left behind in the Console.
11/13/08 7:43:08 PM [0x0-0x1f01f].org.qgis.qgis[273] Warning:
Object::connect: No such slot QgsComposer::undo()
Object::connect:  (receiver name: 'QgsComposerBase')
Object::connect: No such slot QgsComposer::cut()
Object::connect: No such slot QgsComposer::copy()
Object::connect: No such slot QgsComposer::paste()
11/13/08 7:43:08 PM [0x0-0x1f01f].org.qgis.qgis[273] Fatal Python
error: Interpreter not initialized (version mismatch?)
The last message indicated the possibility of a problem relating to
Python. A few months ago, I had updated to python.org's version and
been using that rather than the system default. On that thought, I
first updated to version 2.6 -- no change. I then tried the system
default. To accomplish this, I removed the nonsystem version from my
path, then restarted the system. After restart, my path checked out as
expected and running which python showed me /usr/bin/python. Doing so
however made no difference as QGIS still crashed with the same console
messages.
Does anyone have any thoughts as to what else I should look at?
My set up is on Mac OS 10.5.5 + all security updates. The system
version of python is 2.5.1. In addition, I have trashed the pref file
as well as moved ~/.qgis temporarily to a different directory.
I will note the previous preview exhibited the same behavior as well,
I just did not have the time to troubleshoot it.
Dan Dittmann
