[Qgis-user] Mac OS X: QGIS 1.0 Preview 2 Crashes
Dan Dittmann
qgis at dandittmann.org
Thu Nov 13 18:55:35 PST 2008
On Nov 13, 2008, at 8:35 PM, William Kyngesburye wrote:
> On Nov 13, 2008, at 7:55 PM, Dan Dittmann wrote:
>> 11/13/08 7:43:08 PM [0x0-0x1f01f].org.qgis.qgis[273] Warning:
>> Object::connect: (receiver name: 'QgsComposerBase')
>> 11/13/08 7:43:08 PM [0x0-0x1f01f].org.qgis.qgis[273] Fatal Python
>> error: Interpreter not initialized (version mismatch?)
>> The last message indicated the possibility of a problem relating to
>> Python. A few months ago, I had updated to python.org's version and
>> been using that rather than the system default. On that thought, I
>> first updated to version 2.6 -- no change. I then tried the system
>> default. To accomplish this, I removed the nonsystem version from
>> my path, then restarted the system. After restart, my path checked
>> out as expected and running which python showed me /usr/bin/python.
>> Doing so however made no difference as QGIS still crashed with the
>> same console messages.
> On OSX Qgis is very particular about which Python is used at
> runtime. Unfortunately, PyQt/SIP, and the Qgis python libraries,
> link directly to the Python framework binary, so only that Python
> binary can be used to load the Qgis python bindings.
> Unlike other systems, on OSX a proper plugin/extension links in a
> different way to its parent than normal dynamic libraries - there is
> no direct link to the parent binary. It expects to be loaded by
> that parent, and thus find all the functions it needs from the parent.
> This makes it simple to to move the parent around (ie Python,
> Apache, PHP) or use different builds (but same version) of the
> parent (ie Apple Python 2.5 vs python.org Python 2.5).
> How this affects Qgis/python: say Qgis is built with the Apple
> Python (like my Leopard Qgis), but you have the python.org python
> (2.5 or 2.6) in your shell PATH. Qgis starts up python, and finds
> python.org's python. But the Qgis python binary parts link to the
> system python - total binary confusion, even though they may be the
> same version, and Qgis crashes.
> So, installing Python 2.6 will cause trouble, if Qgis was built with
> either the system python or python.org python 2.5. If Qgis was
> built with the python.org python 2.5, removing it will cause trouble
> also.
This is sort of the idea I was operating on when I chose to remove
python.org's version from my path.
> It would be nice if PyQt/SIP and Qgis properly linked to python (I
> think Qgis takes its cue from SIP), then it would be easier to
> switch between the system python 2.5 and python.org 2.5.
>> Does anyone have any thoughts as to what else I should look at?
> If Qgis crashed, look in Console.app for the crashlog. If it's just
> quitting with no crash, turning on Qgis debugging may help find the
> problem (sorry, I don't remember how to do that).
If I get ambitious, I'll poke around for this.
>> My set up is on Mac OS 10.5.5 + all security updates. The system
>> version of python is 2.5.1. In addition, I have trashed the pref
>> file as well as moved ~/.qgis temporarily to a different directory.
> Which Qgis are you using - mine (framework-based) or Tom's all-in-one?
Tom's All in one.
I did just download your frameworks and your build of QGIS. That
version works as expected.
Dan
