[QGIS-user] Using GRASS' shell from within QGIS
Agustin Lobo
Agustin.Lobo at ija.csic.es
Fri Nov 14 02:59:22 PST 2008
Nikos,
I think that this is again a consequence of the different point of
view of developers and users: from a user point of view, this is
clearly a bug, it's something that does not work as expected.
The "solution" I'm using is just opening an xterm with xterm &
and can work
from the new terminal with no problem. But this is just a temporary
solution. May be we should at least document the problem and
the workaround, the current situation causes lots of frustration
to newcomers.
Agus
> Message: 6
> Date: Thu, 13 Nov 2008 19:15:29 -0800
> From: Alex Mandel <tech_dev at wildintellect.com>
> Subject: Re: [QGIS-user] Using GRASS' shell from within QGIS
> To: qgis-user <qgis-user at lists.osgeo.org>
> Message-ID: <491CED51.7060903 at wildintellect.com>
> Content-Type: text/plain; charset=ISO-8859-1
> Nikos Alexandris wrote:
>> > Hi all! Apologies for cross-posting.
>> > I don't know how frequently you use GRASS' shell from within QGIS. I
>> > like it but typing, deleting (with backspace) or using
>> > "arrow-keys" (left & right), "home" or "end" doesn't work as expected.
>> > Is it only my installation or is it a known "bug"?
>> > As an extra, I would like to change the font. I don't need it so big and
>> > (why is it by deafult...) italics?
>> > Kind regards, Nikos
> I don't think it's a bug, I think it's a lack of features possibly due
> to a lack of features in QT.
> I'll let the developers weigh in on it but suggest you file a feature
> request on trac.osgeo.org/qgis
> Alex
Dr. Agustin Lobo
Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
LLuis Sole Sabaris s/n
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
email: Agustin.Lobo at ija.csic.es
http://www.ija.csic.es/gt/obster
