[Qgis-user] Mac OS X: QGIS 1.0 Preview 2 Crashes
    William Kyngesburye
    woklist at kyngchaos.com
    Fri Nov 14 07:18:23 PST 2008
On Nov 14, 2008, at 4:41 AM, Martin Dobias wrote:
> On Fri, Nov 14, 2008 at 3:35 AM, William Kyngesburye
> <woklist at kyngchaos.com> wrote:
>> It would be nice if PyQt/SIP and Qgis properly linked to python (I
>> think
>> Qgis takes its cue from SIP), then it would be easier to switch
>> between the
>> system python 2.5 and python.org 2.5.
> William,
> do you have any ideas how to improve the situation of QGIS python
> support on OS X?
> I don't know much about specifics of OS X but we could tweak python
> support with your assistence if you describe what's going wrong.
> Martin
I think we're stuck with what we get from SIP/PyQt.  SIP is, I
believe, what is setting the compile flags.  Even if Qgis post-
processed those flags, SIP and PyQt would still be built that way.
If it's what I think it is, I see in sipconfig.py:
_default_macros = {
'LFLAGS_PLUGIN': '-single_module -dynamiclib',
I could try a bug report to Riverbank... but for now we'll just have
to put up with it, which means making sure the right python is the
default for the Qgis build run.
Short details, so you know what's going on:
A plugin, or "module" on OSX doesn't use normal library linking to a
parent, or loading, binary (library or program), as -dynamiclib -lfoo
(or -dynamiclib -undefined dynamic_lookup for a parent program).
Instead it links as a bundle:
-bundle -bundle_loader /path/to/foo
The -bundle_loader acts in place of the -l flag, so the linker can
find the symbols in the parent, but the library or program is not
actually added to the module's link list.  And a bundle can't be
linked to as a library.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that the
past isn't a fiction designed to account for the discrepancy between
my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
