[Qgis-user] Problems with grass plugin
Agustin Lobo
Agustin.Lobo at ija.csic.es
Wed Nov 19 05:31:35 PST 2008
If I use the arrows to edit the command (which is most used in grass), I
always get weird behavior, cannot edit as I do in an xterm. Sometimes
the right arrow does not work after I've used the left arrow, the lines
that I recover with the up arrow are broken, the terminal gets stuck
very often...
Agus
Barbosa, A. Marcia wrote:
> Hi Agus,
> I don't know of any specific documentation on the GRASS plugin apart from chapter 8 of the QGIS user guide.
> I also find r.mapcalc confusing in the QGIS interface and I've never got down to it. I use either r.mapcalculator for calculations with up to 6 input maps, or r.mapcalc in the GRASS shell (QGIS module), which I actually find quite straightforward (for example, r.mapcalc output="input1+0.25*(input2/input3)"). And there's the additional advantage that, when using the GRASS shell even within QGIS, you don't need to have the inputs on display in the map canvas.
> But what are these problems you have with the GRASS terminal in the plugin?
> Regards,
> Marcia
> A. Márcia BARBOSA
> Department of Biological Sciences
> Imperial College London, Silwood Park Campus
> Ascot, Berkshire SL5 7PY
> UNITED KINGDOM
> Unidade de Macroecologia e Conservação
> CEA - Universidade de Évora, Pólo da Mitra
> 7002-554 Évora
> PORTUGAL
> "Anyway, is there any kind of specific doc on the grass
> plugin? I'm particularly confused by r.mapcalc (I used grass
> in the very old days and use r.mapcalc in the terminal). Any
> doc or tutorial on how to use the graphic interfase? Do you use it?
> BTW, I always have problems with the grass terminal opened from
> the plugin and have to open an xterm. This is not big deal for me,
> but students find it very confusing. Could the grass terminal be fixed?"
Dr. Agustin Lobo
Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
LLuis Sole Sabaris s/n
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
email: Agustin.Lobo at ija.csic.es
http://www.ija.csic.es/gt/obster
