[Qgis-user] select elements from a wms layer
Richard Duivenvoorde rdmailings at duif.net
Fri Nov 21 01:51:26 PST 2008
Not sure if I understand you correctly, but a WFS SHOULD be selectable
in QGIS. Try the 'rijkswaterstaat'-url below, and you can select 1
province, and via the attribute table copy WKT to the clipboard:
wkt_geom,MPPerimete,MPArea,AREA,PERIMETER,OMSCHR,GAQ,NL
MULTIPOLYGON(((149480.042914 476598.605781,149482.755927
... a LOT of coordinates here ...
476598.605781))),265264,143640,1436408320.0000,265278.25000,Utrecht,10,0
But if it is only the LABELS that you actually want to copy, it's
different. Labelplacement is done using the geographic object it's
attached to.
First I thought that you maybe could transform your original layer to a
point-layer, but in that way you do not have the exact same label
locations as before. But having a pointlayer with labels, they should be
selectable, thereby copyable.
Another option?? in arcview it was/is(?) possible to transform a labels
to a 'graphic'...
Regards,
José María Michia wrote:
> With WFS I've come close to what I need. The problem is that WFS does
> not work with layers of labels. I've changed the geometry type, to
> polygon, without style, and with label, and i can display this layer
> in QGIS. I've inserted this WFS layer in QGIS. And, at certain scale,
> QGIS show only the labels that i want to write out. So, QGIS display
> the data that i wish to write to some GIS file. But, QGIS not let me
> select elementos from WFS/WMS layers. Selection tools is deactivated.
> And i cannot found any way of convert to gis format. Only found a way
> to convert it to image.
> Using QGIS, with both WMS and WFS layers, the selection tool is
> deactivated. I can not select elements of these layers. With other
> layer formats, the tool is activated, and I can select elements. Is
> correct this behavior?
>> If you want to try out a WFS: use this url:
>> http://www.rijkswaterstaat.nl/services/geoservices/overzichtskaartnl?service=WFS&typename=NL-prov&version=1.0.0
>> you will be able to receive provinces, highways etc from the Netherlands.
