[Qgis-user] [Fwd: Re: [GRASS-user] [Fwd: grass-related failure when building qgis_0_11]]
Tim Sutton
tim at linfiniti.com
Mon Nov 24 13:24:02 PST 2008
Hi
Its unlikely we will be able to do that right now since I think it is an
inefficient use of scarce manpower to release a 0.11.1 when we are a
month away from releasing 1.0.0. If someone wanted to generate the
required patch, we could certainly make it available, but I dont see us
making a full release cycle for this at this stage.
Regards
Tim
On Mon, 2008-11-24 at 20:32 +0100, Nikos Alexandris wrote:
> Should/can this be backported to qgis_0_11 (see forwarded message)?
> I can't build from source with grass-library defined in ccmake's
> configuration menu. I don't face this problem when building qgis preview
> release(s). With the latter I have a python-related problem... but
> that's another story :-)
> Kind Regards, Nikos
> email message attachment, "Forwarded message - Re: [GRASS-user] [Fwd:
> grass-related failure when building qgis_0_11]"
> > -------- Forwarded Message --------
> > From: Markus Neteler <neteler at osgeo.org>
> > To: Nikos Alexandris <nikos.alexandris at felis.uni-freiburg.de>
> > Subject: Re: [GRASS-user] [Fwd: grass-related failure when building
> > qgis_0_11]
> > Date: Mon, 24 Nov 2008 18:46:09 +0100
> > Nikos,
> > perhaps someone can backport it to 0.11... perhaps
> > timlinux or jef (IRC names).
> > Markus
> > On Mon, Nov 24, 2008 at 6:45 PM, Markus Neteler <neteler at osgeo.org> wrote:
> > > Nikos,
> > > this has been fixed recently in QGIS trunk.
> > > Markus
> > > On Mon, Nov 24, 2008 at 6:24 PM, Nikos Alexandris
> > > <nikos.alexandris at felis.uni-freiburg.de> wrote:
> > >> Sorry for forwarding this in the grass-user list. I must have
> > >> messed up somehow my grass-dev account or I don't know what... I can't
> > >> send anything to grass-dev(?).
> > >> Regards, Nikos
> > >> ---------- Forwarded message ----------
> > >> From: Nikos Alexandris <nikos.alexandris at felis.uni-freiburg.de>
> > >> To: grass-dev at lists.osgeo.org
> > >> Date: Mon, 24 Nov 2008 07:49:10 +0100
> > >> Subject: grass-related failure when building qgis_0_11
> > >> Hi all! I get this error when building qgis 0.11 from source. I've read
> > >> the http://trac.osgeo.org/grass/ticket/364 ticket. Is it really fixed?
> > >> This problem does not occur when building qgis preview version.
> > >> [ 71%] Building CXX object
> > >> src/providers/grass/CMakeFiles/qgisgrass.dir/qgsgrassprovider.o
> > >> /usr/local/grass-6.4.svn/include/grass/Vect.h: In static member function
> > >> 'static int QgsGrassProvider::openMap(QString, QString, QString,
> > >> QString)':
> > >> /usr/local/grass-6.4.svn/include/grass/Vect.h:197: error: too many
> > >> arguments to function 'int Vect_build(Map_info*)'
> > >> /usr/local/src/qgis_0_11_0/src/providers/grass/qgsgrassprovider.cpp:1040: error: at this point in file
> > >> /usr/local/grass-6.4.svn/include/grass/Vect.h: In member function 'bool
> > >> QgsGrassProvider::closeEdit(bool)':
> > >> /usr/local/grass-6.4.svn/include/grass/Vect.h:199: error: too many
> > >> arguments to function 'int Vect_build_partial(Map_info*, int)'
> > >> /usr/local/src/qgis_0_11_0/src/providers/grass/qgsgrassprovider.cpp:1495: error: at this point in file
> > >> /usr/local/src/qgis_0_11_0/src/providers/grass/qgsgrassprovider.cpp:1496: error: at this point in file
> > >> make[2]: ***
> > >> [src/providers/grass/CMakeFiles/qgisgrass.dir/qgsgrassprovider.o] Error
> > >> 1
> > >> make[1]: *** [src/providers/grass/CMakeFiles/qgisgrass.dir/all] Error 2
> > >> make: *** [all] Error 2
> > >> Nikos
> > >> _______________________________________________
> > >> grass-user mailing list
> > >> grass-user at lists.osgeo.org
> > >> http://lists.osgeo.org/mailman/listinfo/grass-user
> > > Open Source Geospatial Foundation
> > > http://www.osgeo.org/
> > > http://www.grassbook.org/
> Qgis-user mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Visit http://linfiniti.com to find out about:
* QGIS programming services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting & Support Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20081124/b00a0ce6/attachment.sig>
