[Qgis-user] edit attribute tables
Michelle Bourassa Stahl
mbstahl at west-inc.com
Wed Nov 26 11:14:37 PST 2008
I am a new user of both GRASS and QGIS. I am using GRASS version 6.3.0 and
QGIS version 0.11.0.
I would like to be able to edit vector layer attribute tables in QGIS but
have not been successful. I need to add a column then enter values in the
column.
If the vector was created from a shapefile with the 'Add a Vector Layer'
then I can open the attribute table and click start editing but the add a
new column button is disabled.
If the vector was created from a GRASS vector layer with the 'Add GRASS
vector layer' then I can use the 'Edit GRASS vector layer' tool and I can go
to the Table tab and add a new column to the table then I click on the Edit
attributes' button and nothing happens. The button is on and if I open the
attribute table the table is blank. So if I close the Edit GRASS vector
layer tool and then right click on the layer in the legend and click open
attribute table, I get the complete attribute table but the start and stop
editing and add and remove column buttons are disabled.
I saw some threads about editting GRASS vector layer attribute tables from
2005 in the archives and all indicated that you cannot edit the attribute
table for a GRASS vector layer. Is this still the case? Is it still not
possible to edit the attribute table for a GRASS vector layer?
Also, as indicated above, I am not successful in completing the type of edit
I want (add a column and fill with values) with either a vector layer
created from a shapefile or a GRASS vector layer. Please advise if I have
missed some simple step to edit attribute tables.
Michelle
Biometrician
Western EcoSystems Technology, Inc.
200 S. 2nd Street, Suite B
Laramie, WY 82070
Office: 307-634-1756 Direct: 307-755-9725
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20081126/c20b10d1/attachment.html>
