[Qgis-user] Big sharing problem - Slow when data are shared in more than one user - QGIS 0.11
Mike Toews
mwtoews at sfu.ca
Thu Nov 27 16:05:35 PST 2008
Micha Silver wrote:
> Could you elaborate on the "extra software and database setup" bit?
> Many thanks,
> Micha
Hi Micha,
To connect PostGIS with ArcGIS products (basic ArcView license and up)
you can use zigGIS (http://pub.obtusesoft.com/). This program used to be
open source (see http://code.google.com/p/ziggis/ although I've had no
luck making it work with 9.2). The developer has since commercialized
and revamped the program with a $279 price tag. (In context and ranting
in Canadian dollars, ArcView is about $3000, but the minimum license
required to connect and edit with an ArcSDE spatial database is
ArcEditor, which is about $10000. I think ArcInfo is about $20000, and
ArcSDE is about $15000 not including database software, which ranges
from $0 for PostgreSQL to $5000 for MS SQL Server and to $60000 for
Oracle Spatial). ZigGIS adds some GUI controls to ArcGIS, and it has
read/write capabilities. The demo is worth a try, but it only shows a
limited number of rows. I don't have a lot of experience with this
product, so I can't say too much about any limitations except that it
appeared to work fine.
To connect PostGIS with Autodesk products (i.e., AutoCAD Map 3D 2008 and
up, MapGuide Enterprise or MapGuide Opensource) you can use the PostGIS
Provider for FDO (http://trac.osgeo.org/fdo/wiki/FdoPostGISNotes in
addition I recommend using the Windows DLLs from
http://www.geomapgis.com/web/geomap-group/fdo/index.html). However, this
FDO Provider is regarded as beta-quality in every sense (see "Open
Tickets" on Trac page). I've run into many issues with this driver, but
have overcome many of these with customized trigger functions that
synchronize a second replica table for FDO clients. The nice thing about
this effort is that the CAD folks where I work can continue to use
familiar software to digitize coordinates, polylines, etc., and the
geospatial data are identical in QGIS and AutoCAD displays at all times.
I've also used PostGIS for a limited amount of time with Manifold System
(http://www.manifold.net/), which has built-in support. However, I've
had issues with adding and editing shapes since it commits edits
instantly without any ability to fill in attributes before, which
usually raises PostgreSQL constraint errors (e.g., I need to assign a
unique non-null name to each new feature of a certain layer).
With all that said, by far my best PostGIS experience with a desktop app
is with QGIS, since it works "out of the open source box". I don't need
to fabricate any database workarounds for QGIS as I do for FDO, which is
of great convenience. The people at my workplace that are using QGIS
(starting since 1 month ago) have picked it up quickly, and the value of
GIS in the office has gone up quite a bit, since it is no longer
exclusive to the few technicians with expensive software.
-Mike
