[Qgis-user] DXF import
Justin Fischer
jfischer at fcaog.state.ut.us
Thu Oct 9 13:36:27 PDT 2008
After wrestling against some dependency issues I was able to install
preview 1 and the dxf2shp plugin is working! This is so cool! The
ability to import dxf files should be a huge time saver. Thanks to all
the devs working on what is becoming a great project.
Justin
On Thu, 2008-10-09 at 01:09 +0200, Werner Macho wrote:
> Hi!
> I think you mean the Dxf2Shp Converter available as a Plugin.
> I'm not sure it it is already in Metis but in the new preview1 there it
> is surely selectable allthough I've made some strange experiences
> especially with 3d-dxf files import.
> But it is surely worth a try.
> hope this helps
> regards
> Werner
> Justin Fischer wrote:
> > Hi list,
> > I've read that there is a DXF to Shapefile converter (e.g.,
> > http://www.nabble.com/dxf2Shp-plugin-td16357138.html and
> > https://trac.osgeo.org/qgis/ticket/1269 ). I have not yet been able to
> > find a plugin in Metis on Ubuntu Hardy that will work with DXF files.
> > The only workaround I've seen is to use gvSIG, then bring the shapefiles
> > to QGIS. Can someone please direct me?
> > Thank you,
> > Justin
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
