[Qgis-user] If the plugin installer doesn't work in QGIS > r9471
Borys Jurgiel
borys at wolf.most.org.pl
Sat Oct 11 11:33:48 PDT 2008
Hi lists,
Recent API changes affect older versions of the plugin installer (< 0.06.4).
So if after recompiling QGIS from trunk the installer doesn't start, remove
the ~/.qgis/python/plugins/plugin_installer directory to unmask the built-in
instance, which of course works (thanks Jef!). Then you can safely upgrade it
to a recent version.
Regards,
B.
