[Qgis-user] qgis crashes when opening a GRASS raster and vector maps
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Mon Oct 13 10:18:17 PDT 2008
On Mon, 2008-10-13 at 10:01 -0400, Kurt Springs wrote:
> Hi folks,
> I am running Qgis under OS X 10.5.5.
> I have been using the plug-ins to import the GRASS raster and vector
> maps. Each time I try to import the map, qgis quits with no warning
> and no message that it has unexpectedly quit. I was hoping someone
> could tell me why and how to fix it. I am running 1.0.0 preview, but
> it has been happening on the last couple of versions as well.
> I don't know if this means anything but I get a pop-up that says "QGIS
> couldn't find your GRASS installation. Would you like to specify path
> (GISBASE) to your GRASS installation. I have tried several things but
> none of them seem to satisfy this message. Could someone tell me what
> I should be aiming for to specify the path?
> Thanks in advance for your help.
> Kurt Springs
Dear Kurt,
maybe you need to clean your system from files belonging to previous
qgis installations. I had similar issues with QGIS under Ubuntu. I just
*erased* everything related to qgis (from previous installations) and
did a clean installation (compilation from source) and now it runs fine.
Kind regards, Nikos
