[Qgis-user] Re: Odd Null value
Peter Ersts
ersts at amnh.org
Mon Oct 20 07:41:43 PDT 2008
Agustin,
You will notice that that image does not have a valid NoDataValue by
default, which is why the field in the properties dialog is blank.
The transparency table and NoDataValue field can handle scientific
notation just fine. The problem is that -3.40282e+38 is NOT the "exact"
value of the pixel, so the no data and transparency checks fail.
Overly simplistic example
( 3.2e+01 == 3.28 ) is false.
The "value tool plugin", if that is what you are using to find the
values, should let you choose between scientific notation and actual
value for output display. Maybe the documentation or metadata for the
project that produced that image will have a detailed description of
pixel values.
-pete
Agustin Lobo wrote:
> I have a raster map
> (http://sedac.ciesin.columbia.edu/es/npp_geotiff.zip)
> with the odd value of
> -3.40282e+38
> as null value (this is probably the way some software is writing its
> null values)
> Is there any way I can set this value as NO DATA VALUE in QGIS?
> I have the impression that the field in the Transparency tab does not
> accept the e+38
> I've been able to set it in the transparency list thanks
> to the tool that lets you select in the image, but then
> cannot copy and paste.
> Thanks
> Agus
Peter J. Ersts, Project Specialist
American Museum of Natural History
Center for Biodiversity and Conservation
Central Park West at 79th Street
New York, New York 10024
Tel: Home Office (518)-632-4745 or NYC Office (212)-496-3488
Web: http://biodiversityinformatics.amnh.org
Web: http://cbc.amnh.org
Quantum GIS Raster Development Team. Visit http://www.qgis.org
to learn more about QGIS, a free and open source desktop GIS
Open Source,
...evolving through community cooperation to change the world bit by bit
