[Qgis-user] scaling bug?
Magnus Homann
magnus at homann.se
Wed Oct 22 03:58:56 PDT 2008
Werner Macho skrev:
> Hi again!
> Ok I must miss something somewhere..
> I open QGIS .. Set the project projection to M34.
> Load the shape file as a vector layer - set the Layer projection to
> M34 (missed that before) .. but .. the same happens
> Project has +proj=tmerc +lat_0=0 +lon_0=16.33333333333333 +k=1
> +x_0=750000 +y_0=0 +ellps=bessel
> +towgs84=577.326,90.129,463.919,5.137,1.474,5.297,2.4232 +units=m
> +no_defs
> Layer CRS is +proj=tmerc +lat_0=0 +lon_0=16.33333333333333 +k=1
> +no_defs
> Beat me but where can i find the "coordinate transformation turned
> on?" switch?
The last part is the key to the entire mystery! :-)
When you install QGIS, degrees is the default unit, and it tells QGIS
that any coordinate in your layer is in degrees. As you have large >>360
values of coordinates, the scale calculation breaks down. Calculating
scale is done by projecting coordinates sin the center of the canvas
to an ellipsoid. Hairy stuff. This projection is not reliable with
unrealistic values. Remember QGIs thinks that your coordinate (6848,
272169) is in degrees.
Now, you can either change this to meter manually in the option dialog
OR you can turn on projection (top left corner in dialog where you
select project CRS in project properties). In the last case, the unit is
set to what the project projection ("+units=m") says.
Hope this explains it all.
magnus
