[Qgis-user] Problem an the ploting contour lines
Andreas Neumann
a.neumann at carto.net
Thu Oct 23 23:53:10 PDT 2008
Hi Alexandre,
QGIS by itself does not offer this functionality. Maybe a plugin.
However, you can use QGIS together with GRASS. GRASS offers this
functionality. You'd have to import your text file into a GRASS dataset
and then use the command r.contour. See
http://grass.itc.it/gdp/html_grass63/r.contour.html
QGIS offerst a GRASS toolbox plugin where you can do issue the GRASS
commands from within QGIS.
I'd recommend reading the GRASS docus or buying the GRASS book by Markus
Neteler/Helena Mitasova.
Hope this helps as a starter to find more information on the topic.
Andreas
> Hello,
> The my problem is to create a map with contour lines.
> My file text is constituting by : latitute (y), longitude (x) and
> precipitation (z).
> Want to plot the contour lines of precipitation with the qgis.
> This is possible? How I could do this in qgis?
> Thanks!
> SECRETARIA DE ESTADO DO MEIO AMBIENTE E DOS RECURSOS HÍDRICOS
> DIRETORIA DE METEOROLOGIA
> ALEXANDRE S. DOS SANTOS
> TEL.: 82-33152686
> Qgis-user mailing list
Andreas Neumann
Böschacherstrasse 6, CH-8624 Grüt/Gossau, Switzerland
Email: a.neumann at carto.net, Web:
* http://www.carto.net/ (Carto and SVG resources)
* http://www.carto.net/neumann/ (personal page)
* http://www.svgopen.org/ (SVG Open Conference)
* http://www.geofoto.ch/ (Georeferenced Photos of Switzerland)
