[Qgis-user] Reprojection tool?
Giovanni Manghi giovanni.manghi at gmail.com
Mon Oct 27 04:14:48 PDT 2008
Hi Agustin,
in the 1.0 preview I see that in the ftools plugin there are two tools
under the "data management tools" menu:
"export to new projection"
and
"define current projection".
maybe is what you are looking for.
take care
-- Giovanni --
On Mon, 2008-10-27 at 12:03 +0100, Agustin Lobo wrote:
> Hi!
> Is there anybody working on a reprojection plugin
> (at least for vector data)? I mean saving a new shp
> file with a different projection, not just on the
> fly. Or is this
> something that can already be done?
> I'm using the following ogr2ogr command, but actually
> have to use qgis to look at the codes, so a menu based tool
> would make sense:
> $ ogr2ogr -f "ESRI Shapefile" prova_ICC_geogWGS84.shp -s_srs EPSG:23031
> -t_srs EPSG:4326 prova_ICC.shp
> Agus
