[Qgis-user] Re: proportional symbols
G. Allegri
giohappy at gmail.com
Mon Oct 27 06:59:25 PDT 2008
Is it me or it is a common problem? I couldn't have answers neither on
ml nor on the trac...
2008/10/19 G. Allegri <giohappy at gmail.com>:
> I migrate here a discussion started in a ticket
> https://trac.osgeo.org/qgis/ticket/960
> I change the question asking the following: how to make proportional
> symbols, i.e. with the size based on a certain attribute?
> I thought I should use the "Area scale fields" in the Properties
> window. It does the work, but it doesn't scale the sttribute values,
> so if the they are "big" the symbols overlay each other even covering
> the entire screen.
> I show two images about this:
> Property dialog: http://www.geospatial.it/allegri/property.png
> Result: http://www.geospatial.it/allegri/graduated.png
> I've used the lower allowed "Dimension" (=3)...
> Am I using a tool that wasn't supposed to do this work? Or am I using
> it in the wrong way?
> Giovanni
