[Qgis-user] Reprojection tool?
Agustin Lobo
Agustin.Lobo at ija.csic.es
Mon Oct 27 14:00:24 PDT 2008
I think that there is a bit of confusion just because
we are in the middle of a big change and some are using
the stable 0.11 and others the preview of 1.0. I've just used
the Save as shapefile option in QGIS 1.0Preview from
ubuntu binaries and works very well, it's just
what I was needing!
Thanks a lot!
Agus
Magnus Homann wrote:
>>> Agustin Lobo skrev:
>>>> Hi!
>>>> Is there anybody working on a reprojection plugin
>>>> (at least for vector data)? I mean saving a new shp
>>>> file with a different projection, not just on the
>>>> fly.
>>> You can select (right-click in legend) "Save as shapefile..." and the
>>> layer will be saved inr the current project projection (if turned on).
>> This has not been my experience. "Save as shapefile" saves in the same
>> projection as the original, not in the project projection.
> Correction! It asks for what proejction to save as. Misremembered. :-)
> This was introduced in r9334. I'm not sure if it made it into preview 1.
> Magnus
Dr. Agustin Lobo
Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
LLuis Sole Sabaris s/n
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
email: Agustin.Lobo at ija.csic.es
http://www.ija.csic.es/gt/obster
