[Qgis-user] proportional symbols
Goyo
goyodiaz at gmail.com
Mon Oct 27 14:40:25 PDT 2008
OK I read the ticket and I think I've got the point now. First of all
you'll want to know that the lower size limit is gone in 1.0 but I don't
think you're going to get good looking results with your data anyway.
So you want to tell the sizes for maximum and minimum field values
(whatever they are) and get the size for any value computed by linear
interpolation.
To be honest I don't see this useful enough (in general) as to justify
the additional clutter in UI. On the other hand that's the way colormaps
are handled in rasters, more or less.
Just some thoughts.
Goyo
El lun, 27-10-2008 a las 21:49 +0100, Goyo escribió:
> Hi Giovanny,
> it scales the symbol size, not the attribute values. Since your
> attribute values are big you're getting big symbols.
> Goyo
> El dom, 19-10-2008 a las 21:15 +0200, G. Allegri escribió:
> > I migrate here a discussion started in a ticket
> > https://trac.osgeo.org/qgis/ticket/960
> > I change the question asking the following: how to make proportional
> > symbols, i.e. with the size based on a certain attribute?
> > I thought I should use the "Area scale fields" in the Properties
> > window. It does the work, but it doesn't scale the sttribute values,
> > so if the they are "big" the symbols overlay each other even covering
> > the entire screen.
> > I show two images about this:
> > Property dialog: http://www.geospatial.it/allegri/property.png
> > Result: http://www.geospatial.it/allegri/graduated.png
> > I've used the lower allowed "Dimension" (=3)...
> > Am I using a tool that wasn't supposed to do this work? Or am I using
> > it in the wrong way?
> > Giovanni
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
