[Qgis-user] Windows XP SP3, QGIS 1.0.0 preview & fTools
Dimitar Vasilev dvasilev at gis-sofia.bg
Wed Oct 29 02:38:57 PDT 2008
Hi!
I tryed the new version of fTools (0.4.1) for QGIS 1.0.0 preview over
WinXP SP3
All dialogs work fine before I load any ESRI Shapefile. But after I load
a single shape, all functions in fTools finish with different errors and
none of them works. I mean even the dialog doesn't show.
For example, I added the builtups.shp from Alaska sample dataset and I
tryed fTools -> Data Management Tools -> Export to new projection.That
was the error:
An error has occured while executing Python code:
  File "C:/Documents and
Settings/konsulat/.qgis//python/plugins\fTools\fTools.py", line 309, in
doproject
    d = doReProject.Dialog( self.iface )
  File "C:\Documents and
Settings\konsulat\.qgis\python\plugins\fTools\tools\doReProject.py",
line 23, in __init__
    layer = mapCanvas.layer(i)
AttributeError: layer
Python version:
2.5.2 (r252:60911, Feb 21 2008, 13:11:45) [MSC v.1310 32 bit (Intel)]
Python path:['D:/QGIS-Dev/./python', 'C:/Documents and
Settings/konsulat/.qgis//python/plugins',
'D:/QGIS-Dev/./python/plugins', 'C:\\Program Files\\ArcGIS\\bin',
'D:\\QGIS-Dev\\python25.zip', '', 'D:\\QGIS-Dev', 'C:\\Documents and
Settings\\konsulat\\.qgis\\python\\plugins\\fTools\\tools']
fTools -> Data Management Tools -> Split vector layer. And a different
error appeared:
Settings/konsulat/.qgis//python/plugins\fTools\fTools.py", line 293, in
dosplitVect
    d = doVectorSplit.Dialog( self.iface )
Settings\konsulat\.qgis\python\plugins\fTools\tools\doVectorSplit.py",
line 50, in __init__
Python version:
Every function had a different error line
Also I tryed to install the previous stable version of QGIS 0.11 and
then to install the old version of fTools with no success. It seems that
zip file isn't on Carson Farmer's Repository anymore. I browsed the
repository manually with a webbrowser, found the zip file for old fTools
plugin and when I clicked on it to download it browser said that file
wasn't found.
Any help?
Regards!
D. Vasilev
GIS-Sofia EOOD
Bulgaria
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20081029/a9aa7d3a/attachment.html>
