[Qgis-user] Projection question
Mikhail Umorin
Mikhail.Umorin at twdb.state.tx.us
Thu Apr 2 06:51:46 PDT 2009
Thank you for the suggestions, Zoltan —
Unfortunately, no luck. I enabled "on the fly" and set project's CRS to
WGS84 (same as the GoeTiff's) but no changes in the way they are
rendered in QGIS: different size and far from each other.
What else can I try?
Mikhail.
>>> On 4/1/09 at 3:14 AM, in message
<Pine.LNX.4.64.0904011008270.32081 at bme-geod>,
Siki Zoltan <siki at agt.bme.hu> wrote:
> Hi Mikhail,
> Did you enable on the fly projection in the project properties
window?
> QGIS cannot reproject rasters on the fly, so you must set your
project
> projection to the same projection of your raster layer. QGIS will
> reproject vectors on the fly.
> regards,
> Zoltan
> On Tue, 31 Mar 2009, Mikhail Umorin wrote:
>> Hello ̇̇
>> I have a problem with rendering layers with different projections.
I
>> have an SHP file with "+proj=longlat +ellps=GRS80 +datum=NAD83
+no_defs"
>> and a geoTIFF file with "+proj=longlat +ellps=WGS84 +datum=WGS84
>> +no_defs". That's all the projection data from "Properties". They
cover
>> exactly the same area but do not even overlap in QGIS. I also
noticed
>> that when geotiff file is rendered the distances that should be 3
>> degrees are shown as about 10 degrees (my project options are set
to
>> Decimal Degrees) . I suspect that there is some confusion with
>> meters/feet somewhere in the reprojection process.
>> Is there any way to add "+units" option to the description of the
>> layer's projection? Would this solve the problem?
>> Thank you for your time,
>> Mikhail.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
