[Qgis-user] segmentation fault on WMS/WFS connect
Goyo
goyodiaz at gmail.com
Wed Apr 29 12:40:15 PDT 2009
El mié, 29-04-2009 a las 16:08 +0200, Michele Beneventi escribió:
> Hi goyo,
> I have the crash in the connection to the services.
> Thank you
> Michele
Do you mean after you select the server an then press the connect
button? I don't have any problems connecting to any of them. If we are
using the same OS and qgis package it must be some difference in the
setup but I don't know what's going on.
> On Tue, Apr 28, 2009 at 10:07 PM, Goyo <goyodiaz at gmail.com> wrote:
> El mar, 28-04-2009 a las 16:51 +0200, Michele Beneventi
> escribió:
> > Hi list,
> > I've installed qgis "kore" 1.0.1 on Ubuntu 9.04 from its
> repository.
> > It works until I try to load the wms and wfs services;at
> this point qgis
> > crashes with this message:
> > "segmentation fault"
> > the URLs are:
> > http://webgis.regione.sardegna.it/geoserver/wms?
> http://webgis.regione.sardegna.it/wmsconnector/com.esri.wms.Esrimap/ras_wms?
> > http://webgis.regione.sardegna.it/geoserver/wfs?
> I'm having issues with some layers from these servers but no
> crashes.
> Using qgis 1.0.1-1~jaunty.
> Which layers are you having problems with?
> Michele Beneventi - Sardegna IT
> c/o
> Assessorato Enti Locali, Finanze ed Urbanistica
> Direzione Generale Pianificazione Urbanistica Territoriale e Vigilanza
> Edilizia
> Servizio Informativo e Cartografico regionale
> Viale Trieste 186 - 09123 Cagliari
> Tel: +39 070 606 5818
