[Qgis-user] Question on how to add data to shapefiles
Carbonari, Katie (IS)
Katie.Carbonari at ngc.com
Mon Dec 7 05:53:32 PST 2009
Thanks for the advice. To answer your question, my grid is not a regular grid. My grid is defined in one of my shapefiles. When you look at the shapefile in Attribute table, this is what you see:
IED X Y KS
1 453780.594 3961930.333 3
2 515181.635 3977431.333 3
3 568577.604 4179629.000 3
where IED is the cell number I mentioned before, X and Y are in UTM coordinates, don't know what KS (it's always 3). So the ascii file I want to add has 2 columns, the first being 1 through length of file that corresponds with the IED value in my shapefile and the second column is the data.
Thanks,
Katie
-----Original Message-----
From: Swapnil Chaudhari [mailto:sslan at rediffmail.com]
Sent: Sat 12/5/2009 7:17 AM
To: Carbonari, Katie (IS)
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Question on how to add data to shapefiles
Dear Katie,
There is a way to get this work done, I'm not sure if it is the right way though.
Use the plugin name delimited text layer. You will have to save your ASCII file to .csv format which is possible in windows notepad.
Feed in the details when you open the plugin.
What surprises me is, ".....There are 200,000 lines in each ASCII file, with each line corresponding to the cell numbers in the shapefiles." I'm not sure what you mean by cell number. Is it raster that has been converted to vector.
Hope it works
Cheers
On Fri, 04 Dec 2009 21:54:01 +0530 wrote
Good morning. I'm new to GIS and very new to QGIS. I have 3 files I need to visualize. 2 are shapefiles that I easily visualized in QGIS. The other file is an ASCII text file that has various parameters. There are 200,000 lines in each ASCII file, with each line corresponding to the cell numbers in the shapefiles. I want to visualize the data in the ASCII file using the same grid in the shapfiles. Does anyone know a way to do this? Any help would be appreciated.
Thanks,
Katie
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20091207/8695a542/attachment.html>
