[Qgis-user] Problem with SDA4PP/Linked Statistical Display
Volkan Kepoglu vkepoglu at gmail.com
Wed Dec 9 05:10:17 PST 2009
my rpy version is 2.0.6, maybe we can test our code results at the same
time.
>>> import rpy2
>>> import rpy2.robjects as robjects
>>> print(rpy2.__version__)
2.0.6
>>> print(robjects.r)
<rpy2.robjects.R object at 0x02A8FFB0>
platform: i386-pc-mingw32
arch: i386
os: mingw32
system: i386, mingw32
status:
major: 2
minor: 9.0
year: 2009
month: 04
day: 17
svn rev: 48333
language: R
version.string: R version 2.9.0 (2009-04-17)
>>> r = robjects.r
>>> r.require("iplots")[0]
True
>>> r.require("iplots")
<RVector - Python:0x02A8A3C8 / R:0x02950AB8>
>>> r.require("iplots").r_repr()
'TRUE'
>>> r.require("ade4")[0] # not installed yet
False
>>> # so, now, the system is working pefect
python 2.5.2
winXP sp3 64bit
On Wed, Dec 9, 2009 at 3:02 PM, Anne Ghisla <a.ghisla at gmail.com> wrote:
> On Wed, 2009-12-09 at 14:51 +0200, Volkan Kepoglu wrote:
> > On Wed, Dec 9, 2009 at 2:24 PM, Anne Ghisla <a.ghisla at gmail.com>
> > wrote:
> > On Wed, 2009-12-09 at 04:17 -0800, Volkan Kepoglu wrote:
> > > updated with ver. 0.142, could you try that if it is fixed?
> > > 1. added loading of rJava package function
> > > 2. changed the style of loading of iplot package: first checks the
> > > package installed or not
> > > and then loads the package but skips to control the package whether
> > it
> > > is loaded or not,
> > > because, most probably, i think that there is a bug for iplots
> > > package. even it is loaded, sometimes do not return true.
> > > for this reason, i prefered not to control the library whether
> > loaded
> > > or not.
> > Hi Volkan, list,
> > sounds like the ade4 load failure for HomeRange_plugin
> http://sourceforge.net/tracker/?func=detail&aid=2830501&group_id=48422&atid=453021
> > does the require(iplots) work on R?
> > the real problem is that i could not produce the same error in every
> > time.
> > sometimes it works and sometimes not.
> Same for me and users that report the problem. Only thing for ade4, I
> encountered it mainly on Windows, and R alone showed no problems. It can
> be a rpy2 version issue. Unfortunately, extensive testing has not been
> done. Let me know how I can help.
> my 2 cents..
> Anne
Regards,
Volkan Osman Kepoglu
PhD Candidate
GGIT Department in METU,
http:/ggit.metu.edu.tr
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20091209/ecdd211e/attachment.html>
