[Qgis-user] Re: [AniMov] Help with HomeRange_plugin on MacOS
Anne Ghisla a.ghisla at gmail.com
Thu Dec 10 13:40:52 PST 2009
Hi all Mac OS users,
thanks to Massimo aka Epifanio, Snow Leopard is now officially a
tested platform for HomeRange_plugin, without compilation (except
QGIS, but it's not required):
http://www.qgis.org/wiki/HomeRange_plugin#Current_.28rpy2.29_working_configurations:
see details of installation here:
http://www.qgis.org/wiki/HomeRange_plugin#Mac_OSX_Snow_Leopard
feel free to report any other working configurations or problems.
all the best,
Anne
On Thu, Dec 10, 2009 at 10:47 AM, HÅKON BORCH <hborch at mac.com> wrote:
> Helo
> I have the sam problem with all my plugins that use R, and I have been looking for a installer package of Rpy2 without success. I just find the source code that has to be compiled for OSX. I don´t have time to spend on learning to make installer packages myself (my need for this is not high enough) so I hope there is somebody out there who have made an installer package. Anybody that can help?
> regards
> Håkon
> Den 10. des. 2009 kl. 10.26 skrev Anne Ghisla:
>> On Wed, 2009-12-09 at 19:16 -0600, Sebastian Cruz wrote:
>>> Hello,
>>> I have installed the new QGIS MIMAS on my Apple, OS 10.6. I have
>>> installed the Homerange plugin, with depedencies (I think). But when I
>>> try to run the plug in I get the following message:
>>> An error has occured while executing Python code:
>>> Traceback (most recent call last):
>>>  File
>>> "/Users/sebastiancruz/.qgis//python/plugins/HomeRange_plugin/HRplugin_dialog.py", line 76, in
>>>    QObject.connect(self.buttonBox, SIGNAL("accepted()"), lambda
>>> mth=mth: self.run(mth))
>>>  File
>>> "/Users/sebastiancruz/.qgis//python/plugins/HomeRange_plugin/HRplugin_dialog.py", line 178, in run
>>>    if not robjects.r.require(i)[0]:
>>> NameError: global name 'robjects' is not defined
>> Hi Sebastian,
>> I'd say that you forgot to install rpy2. But the error you pasted comes
>> after the check for rpy2 at the beginning of the file. I'll ask you to
>> test this line in the QGIS Python console:
>> import rpy2.robjects as robjects
>> and report any errors. If rpy2 is missing, install it, it's a Python
>> package (don't know the details for Mac); if it is installed but QGIS
>> fails to import it, we'll dig a bit more into the problem.
>> regards,
>> Anne
>>> Python version:
>>> 2.6.1 (r261:67515, Jul  7 2009, 23:51:51)
>>> [GCC 4.2.1 (Apple Inc. build 5646)]
>>> Python
>>> path:['/Applications/Qgis.app/Contents/MacOS/../Resources/python',
>>> '/Users/sebastiancruz/.qgis//python/plugins',
>>> '/Applications/Qgis.app/Contents/MacOS/../Resources/python/plugins',
>>> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python26.zip', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-darwin', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-mac', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-mac/lib-scriptpackages', '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-tk', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-old', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload', '/Library/Python/2.6/site-packages', '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/PyObjC', '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/wx-2.8-mac-unicode', '/Applications/Qgis.app/Contents/Resources/python/plugins/fTools/tools']
>>> Do I need to update my Python? Any suggestions are accepted.
>>> Thank you for your help
>>> Sebastian
>>> AniMov mailing list
>>> AniMov at faunalia.it
>>> http://lists.faunalia.it/cgi-bin/mailman/listinfo/animov
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
