[Qgis-user] Question on how to add data to shapefiles
Carbonari, Katie (IS)
Katie.Carbonari at ngc.com
Fri Dec 11 07:50:01 PST 2009
Thanks for the advice but I'm having some issues using the Join Attribute Tool. Every time I try to join 2 files (they are 2 shapefiles, both with the same ID column), QGIS freezes quickly and needs to be restarted. Anyone else have this problem?
Thanks,
Katie
-----Original Message-----
From: Kumaran Narayanaswamy [mailto:kumaran.narayanaswamy at kcubeconsulting.com]
Sent: Mon 12/7/2009 8:34 PM
To: Carbonari, Katie (IS); 'Swapnil Chaudhari'
Cc: qgis-user at lists.osgeo.org
Subject: RE: [Qgis-user] Question on how to add data to shapefiles
Hello Katie,
You can use the Ftools Plugin - Join Attribute tool to do this. Store your
ASCII file as DBF file and using the Join attribute tool using the Join
field (IED) you can link the attributes to the shape file.
Hope this helps.
Regards
Kumaran
[mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Carbonari, Katie
(IS)
Sent: Monday, December 07, 2009 7:24 PM
To: Swapnil Chaudhari
Thanks for the advice. To answer your question, my grid is not a regular
grid. My grid is defined in one of my shapefiles. When you look at the
shapefile in Attribute table, this is what you see:
IED X Y KS
1 453780.594 3961930.333 3
2 515181.635 3977431.333 3
3 568577.604 4179629.000 3
where IED is the cell number I mentioned before, X and Y are in UTM
coordinates, don't know what KS (it's always 3). So the ascii file I want to
add has 2 columns, the first being 1 through length of file that corresponds
with the IED value in my shapefile and the second column is the data.
Thanks,
Katie
From: Swapnil Chaudhari [mailto:sslan at rediffmail.com]
Sent: Sat 12/5/2009 7:17 AM
Subject: Re: [Qgis-user] Question on how to add data to shapefiles
Dear Katie,
There is a way to get this work done, I'm not sure if it is the right way
though.
Use the plugin name delimited text layer. You will have to save your ASCII
file to .csv format which is possible in windows notepad.
Feed in the details when you open the plugin.
What surprises me is, ".....There are 200,000 lines in each ASCII file, with
each line corresponding to the cell numbers in the shapefiles." I'm not sure
what you mean by cell number. Is it raster that has been converted to
vector.
Hope it works
Cheers
On Fri, 04 Dec 2009 21:54:01 +0530 wrote
Good morning. I'm new to GIS and very new to QGIS. I have 3 files I need to
visualize. 2 are shapefiles that I easily visualized in QGIS. The other file
is an ASCII text file that has various parameters. There are 200,000 lines
in each ASCII file, with each line corresponding to the cell numbers in the
shapefiles. I want to visualize the data in the ASCII file using the same
grid in the shapfiles. Does anyone know a way to do this? Any help would be
appreciated.
Thanks,
Katie
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20091211/96e6e312/attachment.html>
