[Qgis-user] Compile error in qgis1.3.0
Salvatore Larosa
s_larosa at libero.it
Sat Dec 12 03:53:12 PST 2009
I get the following error compiling qgis 1.3.0 in debian / lenny:
[ 63%] Building CXX object
src/providers/grass/CMakeFiles/qgisgrass.dir/qgsgrassprovider.o
/usr/local/grass-6.4.svn/include/grass/Vect.h: In static member function
‘static int QgsGrassProvider::openMap(QString, QString, QString, QString)’:
/usr/local/grass-6.4.svn/include/grass/Vect.h:183: error: too few arguments
to function ‘int Vect_build(Map_info*, FILE*)’
/home/sam/dev/cpp/qgis-1.3.0/src/providers/grass/qgsgrassprovider.cpp:1070:
error: at this point in file
/usr/local/grass-6.4.svn/include/grass/Vect.h: In member function ‘bool
QgsGrassProvider::closeEdit(bool)’:
/usr/local/grass-6.4.svn/include/grass/Vect.h:185: error: too few arguments
to function ‘int Vect_build_partial(Map_info*, int, FILE*)’
/home/sam/dev/cpp/qgis-1.3.0/src/providers/grass/qgsgrassprovider.cpp:1567:
/home/sam/dev/cpp/qgis-1.3.0/src/providers/grass/qgsgrassprovider.cpp:1568:
make[2]: ***
[src/providers/grass/CMakeFiles/qgisgrass.dir/qgsgrassprovider.o] Error 1
make[1]: *** [src/providers/grass/CMakeFiles/qgisgrass.dir/all] Error 2
make: *** [all] Error 2
the output of cmake command is as follows:
$ cmake ..
-- Found Proj: /usr/lib/libproj.so
-- Found Expat: /usr/lib/libexpat.so
-- Using GSL from /usr
-- Found GEOS: /usr/lib/libgeos_c.so
-- Found GDAL: /usr/local/lib/libgdal.so
-- Found PostgreSQL: /usr/lib/libpq.so
-- Found GRASS: /usr/local/grass-6.4.svn (6.4.svn)
-- Python libraries found
-- Python bindings enabled
-- Configuring done
-- Generating done
-- Build files have been written to: /home/sam/dev/cpp/qgis-1.3.0/build
Any hint?
Thanks!
View this message in context: http://n2.nabble.com/Compile-error-in-qgis1-3-0-tp4155955p4155955.html
Sent from the qgis-user mailing list archive at Nabble.com.
