[Qgis-user] difficulty changing map projection
Volkan Kepoglu vkepoglu at gmail.com
Wed Dec 16 05:28:30 PST 2009
did you try the existing tool in qgis?
you can reach the tool from the menu:
Tools > Data Management Tools > export to new projection
regards,
volkan
On Wed, Dec 16, 2009 at 3:23 PM, ahmet temiz <ahmettemiz88 at gmail.com> wrote:
> hello
> I have difficulty changing map projection from lamber conical to geographic
> how can I do that ?
> here is the original map's metada:
> name: Lambert Conformal Conic
> proj: lcc
> datum: wgs84
> ellps: wgs84
> lat_1: 40.66666666666666
> lat_2: 43.33333333333334
> lat_0: 0
> lon_0: 34
> x_0: 1000000
> y_0: 0
> no_defs: defined
> I tried with ogr2ogr :
> ogr2ogr -t_srs '+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs'
> -s_srs '+proj=lcc +lat_1=40.66666666 +lat_2=43.333333333 +lat_0=0
> lon_0=34 +x_0=1000000 +y_0=0 +datum=wgs84 +units=meter'
> geohidro_cizgi_adf94.shp hidro_cizgi_adf.shp
> regards
> Ahmet Temiz
> Qgis-user mailing list
Regards,
Volkan Osman Kepoglu
PhD Candidate
GGIT Department in METU,
http:/ggit.metu.edu.tr
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20091216/76d01960/attachment.html>
