[Qgis-user] By default setting of raster transparency values
Agustin Lobo alobolistas at gmail.com
Wed Dec 16 06:56:13 PST 2009
Good idea. In that case, would the color stretching
be set globally as well? Or could each image
keep its own?
Agus
Andreas Neumann wrote:
> Hi Agus,
> how about building an image catalogue with .vrt ?
> See
> http://geosauce.wordpress.com/2009/10/04/building-a-virtual-raster-tutorial/
> This way you only need to do the setting once.
> Andreas
> On Wed, December 16, 2009 1:46 pm, Agustin Lobo wrote:
>> Hi!
>> I have a set of RGB geotif raster files
>> for which I have to set 0,0,0 as transparent.
>> As I have quite a number of them, setting
>> this transparency is becoming tedious. Is there
>> any way I could set this value for all of them at once?
>> I've tried saving an style file, but this does not
>> seem to work.
>> Thanks
>> Agus
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
