[Qgis-user] projection change
ahmettemiz88 at gmail.com
Thu Dec 17 03:27:31 PST 2009
thank you again
Original map is in *adf format it's metadata like this:
name: Lambert Conformal Conic
proj: lcc
datum: wgs84
ellps: wgs84
lat_1: 40.66666666666666
lat_2: 43.33333333333334
lat_0: 0
lon_0: 34
x_0: 1000000
y_0: 0
no_defs: defined
I save it as shp fie in QGIS.
then I am trying to convert it lat/long with ogr2ogr as:
ogr2ogr -t_srs EPSG:4326 -s_srs '+proj=lcc +lat_1=40.66666666
+lat_2=43.333333333 +lat_0=0 lon_0=34.0 +x_0=1000000 +y_0=0 +datum=wgs84
+spheroid=wgs84 +units=m +no_defs' geohidro_cizgi_adf2.shp
hidro_cizgi_adf.shp
17 Ara 2009 12:50 tarihinde, Micha Silver <micha at arava.co.il> şunu yazdı:
> On 17/12/2009 10:49, ahmet temiz wrote:
> thank you
> I tried as you have suggested. But there seems to be something wrong.
> resulting map's extent looks weird.
> I agree with you on that...
> Are you sure about the original shapefile projection? Does it have an
> attached *.prj file? If yes, then you should be able to run ogr2ogr
> *without* specifying the -s_srs.
> I can't find in the EPSG database any projection with your parameters. Is
> it some special CRS?
> $ ogr2ogr -t_srs EPSG:4326 -s_srs '+proj=lcc +lat_1=40.66666666
> +lat_2=43.333333333 +lat_0=41 lon_0=34.0 +x_0=1000000 +y_0=0
> +datum=wgs84 spheroid=wgs84 +units=m' geohidro_cizgi_adf2.shp
> hidro_cizgi_adf.shp
> orkun at orkun-desktop:~$
> orkun at orkun-desktop:~$ ogrinfo geohidro_cizgi_adf2.shp -al -summary
> INFO: Open of `geohidro_cizgi_adf2.shp'
> using driver `ESRI Shapefile' successful.
> Layer name: geohidro_cizgi_adf2
> Geometry: Line String
> Feature Count: 4929
> Extent: (-28.672066, 75.100678) - (37.866883, 81.508631) *****
> Layer SRS WKT:
> GEOGCS["GCS_WGS_1984",
> DATUM["WGS_1984",
> SPHEROID["WGS_1984",6378137,298.257223563]],
> PRIMEM["Greenwich",0],
> UNIT["Degree",0.017453292519943295]]
> UserId: Integer (10.0)
> FNODE_: Integer (10.0)
> TNODE_: Integer (10.0)
> LPOLY_: Integer (10.0)
> RPOLY_: Integer (10.0)
> LENGTH: Real (32.3)
> HIDRO_CIZG: Integer (10.0)
> F_CODE: String (80.0)
> F_NAME: String (80.0)
> SYMBOL: Integer (10.0)
> DISPSCALE: Integer (10.0)
> 2009/12/16 Micha Silvermicha at arava.co.il>:
> ahmettemiz88 at gmail.com wrote:
> hello
> I have difficulty changing map projection from lamber conical to
> geographic ?
> how can I do that ?
> here is the original map's metada:
> proj: lcc
> datum: wgs84
> ellps: wgs84
> lat_0: 0
> lon_0: 34
> x_0: 1000000
> y_0: 0
> no_defs: defined
> I tried with ogr2ogr :
> ogr2ogr -t_srs '+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs' -s_srs
> '+proj=lcc +lat_1=40.66666666 +lat_2=43.333333333 +lat_0=0 lon_0=34
> +x_0=1000000 +y_0=0 +datum=wgs84 +units=meter' geohidro_cizgi_adf94.shp
> hidro_cizgi_adf.shp
> I think you might be having trouble with the quoting. Maybe try with just
> the EPSG code, ie:
> ogr2ogr -t_srs EPSG:4326 geohidro_cizgi_adf94.shp hidro_cizgi_adf.shp
> Micha
> regards
> Ahmet Temiz
> This mail was received via Mail-SeCure System.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20091217/4d0fb4c6/attachment.html>
