[Qgis-user] qml symbology file to arc* format ?
    Agustin Lobo
    alobolistas at gmail.com
    Mon Dec 21 10:22:04 PST 2009
Thank you all, but I'm needing the other way around: I've generated
a layer with QGIS, have to export it as shape and want to
create the arcview legend file (avl ?) or
the equivalent for arcgis from the qml file.
Or is it that arc* is able to read the sld format?
Sorry but I dont use arc* at all
Anyway, as for now qgis does not write sld either, does it?
Agus
Alex Mandel wrote:
> Paolo Cavallini wrote:
>> G. Allegri ha scritto:
>>> I don't think Agus, becasue AFAIK the esri layer files (.lyr) are a
>>> binary closed format.
>> Can Arc* export to a (sort of) standard format?
>> In my view, converging towards a standard one (e.g. sld, with additional tags as
>> necessary) would be the way to go, in the long term.
>> All the best.
> I have seen an Arc2SLD plugin, I think this is it.
> http://apps.geoinform.fh-mainz.de/arcmap2sld/ArcMap2SLDConverter_Eng.htm
> Alex
> Qgis-user mailing list
