[Qgis-user] Alternative schemas for postgis geometry_columns?
Mike Toews
mwtoews at sfu.ca
Mon Dec 28 10:37:50 PST 2009
Mike Toews wrote:
> 2. Create views to the two tables in the public schema (assuming you
> kept this as from the default):
> CREATE OR REPLACE VIEW spatial_ref_sys AS SELECT * FROM
> postgis.geometry_columns;
... oops, corrections:
CREATE OR REPLACE VIEW public.spatial_ref_sys AS SELECT * FROM
postgis.spatial_ref_sys;
CREATE OR REPLACE VIEW public.geometry_columns AS SELECT * FROM
But yes, the "ALTER DATABASE mydatabase SET search_path=public,postgis;"
option is probably the best since now you can use the functions in SQL
like "select st_area(geom);" (rather than "select postgis.st_area(geom);").
-Mike
